Hello to all!
.gif)
I'm able to fabricate some electronic modules, which can improve the functionality of our cars.
The
FMH (follow me home) module can be installed on low beam or for projectors. It has a light sensor which will be set to activate the fmh only in the night. With the help of an rheostat it can be adjusted the light sensor sensibility. The lights will gone ON when the doors are opened and when the doors are locked/unlocked. The time for the lights ON can be personalized: 20,...25,...30... seconds.
It has 6 wires to connect (2 from uch, signal for door open and for central lock) and the final install can be made at the fuse box.
Prices:
More than 5 units = 40 euro/unit;
More than 10 units = 35 euro/unit;
More than 15 units = 30 euro/unit.
The
DRL (daytime running lights) module can be installed on high beam of the car, and that means you protect the low beam durring the daylight. Also keep the dash lights and back lights off. The module is a v4 upgraded version, has only 3 wires to connect on the fuse box, very easy installation. The intensity of the high beam bulbs can be set on 4 values from 18w to 24w and the module will have a 15 seconds delay after the ignition is ON.
Prices:
More than 5 units = 35 euro/unit;
More than 10 units = 30 euro/unit;
More than 15 units = 25 euro/unit.
The
HWM (headlights washer module) is a module which is able to replicate the oem head washers program. It has 6 wires to connect and it's working like this: only when the lights are ON, if keep 2 seconds the windscreen washer, the headlights washers will spray for 2 seconds, first one washer and then the other washer. Of course the time can be set on request, if is wanted another working times.
Prices:
For sure will be many questions, so I'll try to add more details and explanations in order to understand corectly the features of the modules.
This modules are not industrial products, just hand made modules, so the overall appearance is like in the pictures. Anyway, the quality is very high, good quality components and a very high attention on fabrication process.
Finally, if someone has others ideas about fabrication of an customized electronic module, any ideas, i'm looking foward too.
